69CudaFan
Here is what I have. 1969 Plymouth Barracuda 340/4 speed. Mopar conversion (chrome box), Mopar performance coil, fairly new wires and plugs, recently repaced but not by me.
Here is the issue. Started the car last night to go for a quick ride and all seemed well. Fired up, held a good strong idle. Let it warm up for a couple mins (even though I live in SoCal and it was about 70 degrees). Got about 5 mins from my house and literally the car died while it was on the move. Tried to drop it into second and get it to catch as I was pulling to curb. Nothing.
On the side of the road to investigate. I thought it was perhaps a fuel issue or the pump crapped out. Car is getting plenty of good gas, I can see it squirt in when butterfly is open and certainly can smell it. Brand new battery so car cranks over great, but it will just not fire. Then I look at the distributor, and it seemed to move pretty freely to the left and right. I had a friend move it while I was cranking it, then put it back where it was when that did not work.
I just was wondering where should I start on this one. I have a new set of plugs on standby and really want to get this car running stong by the weekend. I am a newb to ignition troubles and have done some reading where people say "check the ballast resistor" or your box is bad. This problem seemed to come on all of the sudden. Should I pull the coil wire and check for spark? Or should I start at the plugs and work backward? I do not want to blindly throw parts at the problem but I do want to solve this. I do not have a multimeter, timing light or things like that, just the basic shadetree mechanic's tool set (rachets and wrenches). I am sure I can do the work with some solid directions from the FABO community. I would be eternally grateful.
