So I have a 383 with radiator from a 70 newport in my 69 dart it's a 22" no shroud will a 75 dart 318 shroud fit I'm sure it's a 22" also. Just wondering if it will lign up in the correct place I'm assuming yes
For what it's worth I have a 383, 22" radiator, 18" fan with a clutch.
I went through this in some thread years ago trying to find a shroud that fits.
Someone chimed in that the fan already takes up the entire air flow of the radiator, so a shroud would be close to useless.
It never overheats, big fan with a clutch was a major improvement.
Don't the larger cars (non A Body) have brackets that bolt to the sides of radiator for the shroud? You would have to have that shroud, it's much wider. The A Body shroud mounts to 4 imbedded nuts in the face of the engine side by the cores. Just went through this.
