69 Dart dome light wire routing
Fabman
Always been MOPARS
Central Florida
Looking for information and pictures showing proper dome light wire routing for 69 Dart.
Thanks in advance
If I remember correctly...the wiring harness for the dome light ties into the rear harness that goes to the tail lights behind the rear seat on the driver's side and runs up the C pillar between the inner framing and outer roof skin at the sail panel and comes out at the top and clips to the stiffening bar across the roof to the dome light.
Hopefully, someone can get you pictures.
Thanks for thee feedback Matt....I will look into that route. I am not using the factory wire harness. Went with a custom Rod harness from American Wire. Really nice harness......
Here are some pictures of the factory wiring. Sorry about the quality of the pictures. First picture wiring from dome light to above drivers door. Second and third pictures is the wiring coming out of the c pillar in the trunk attaching to the taillight wiring. 4th picture is dome light mounts in the rear 2 screw holes and last picture is wiring above drivers door going into c pillar running down to the trunk.
