69 Dart Dyno tune
skep419
5.9 Magnum 4 speed afficionado
Minesoooota
[ame="http://www.youtube.com/watch?v=znd0kyderPY"]YouTube- 69 Dodge Dart GT Dyno[/ame]
Went from 308HP 323 Torque
To 323HP 340 Torque
[ame="http://www.youtube.com/watch?v=mih7BrQA3l4"]http://www.youtube.com/watch?v=mih7BrQA3l4[/ame]
Nice . What are the specs on your engine.
Car-1969 DART GT
Weight-3300
Gear ratio-3.91
Tire diameter-245/60/15
Engine CID-365
Head Type-EDELBROCK
Valve size-2.02 1.60
Head Work- MILD PORT
Cam- Comp Cams 20-225-4
284 int./296 exh.
Carb type and size-HOLLEY 4150HP DP
Jet sizes-72-77
Plug number and brand ngk br6es-11
Intake Manifold Type-RPM AIR GAP
Piston Make-SPEED PRO 4 VALVE RELIEF
Compression Ratio-9-1
Trans type-727
Trans Mods-MANUAL VALVE BODY
Convertor type-MIDWEST CONVERTER
Convertor stall-2800
Trans Brake-no
Drive shaft stock or aftermarket-STOCK
Initial timing-18
Total timing-36
Total advance at what RPM-2000
Rear end type-8 3/4 3.91 742 suregrip, single spline side gears, yukon axles,green bearings.
nice setup . Have you had it on the track?. what times does she run.
I am hoping to get to the track (Thunder Valley Marion SD) 4th of July weekend. Anything that starts with 12.xx would make me smile
good luck, getting into the 12s is pretty tuff. sounds like you may get there though. Get the widest tires possible so you hook up. Took my Dart out last week to the strip. only had a 7" wide drag radial had a hard time hooking up. Finally got traction with 15 psi in the tires.
