Car-1969 DART GT
Weight-3300
Gear ratio-3.91
Tire diameter-245/60/15
Engine CID-365
Head Type-EDELBROCK
Valve size-2.02 1.60
Head Work- MILD PORT
Cam- Comp Cams 20-225-4
284 int./296 exh.
Carb type and size-HOLLEY 4150HP DP
Jet sizes-72-77
Plug number and brand ngk br6es-11
Intake Manifold Type-RPM AIR GAP
Piston Make-SPEED PRO 4 VALVE RELIEF
Compression Ratio-9-1
Trans type-727
Trans Mods-MANUAL VALVE BODY
Convertor type-MIDWEST CONVERTER
Convertor stall-2800
Trans Brake-no
Drive shaft stock or aftermarket-STOCK
Initial timing-18
Total timing-36
Total advance at what RPM-2000
Rear end type-8 3/4 3.91 742 suregrip, single spline side gears, yukon axles,green bearings.
