69 Dart fender reflectors
c0urville
Member
Idaho Falls, ID
Rating - 0%
0   0   0
I am in need for both front and rear reflectors bottom of fenders and rear quarter. Need both the lenses and housings. Not sure if this is the right name for them or not, but they are where turning signal flashers on other cars would be. Thanks Ken cell 208-569-9347
I've got some good used ones for the rear. Contrary to what Juergen says, the rear are different than the ones he linked to. The correct housing is held on with Phillips screws into clip nuts....not studs, bracket and nuts. Also the correct lense has A69PS molded into it whereas other models have A69C. They are the same size and will mount in either housing however. The front side markers are the same as other A and B body cars that year. I'd want $45.00 pair plus UPS for the rear housings and lenses. No good on the front ones at the moment.
Thanks, Mark
