[Found!] 69 Dart Torsion bar crossmember
Scott_ 69HemiDart
That thing got a Hemi...............
West by God Virginia
Rating - 0%
0   0   0
Looking for the torsion bar crossmember part for a ‘69 Dart 4 speed. The arrow in red is pointing to what I need. Let me know if anyone has anything available. Thank you
They are different from 70 -76. The early 67 -69 use larger 1/2 inch bolts where as the 70 -76 use 3/8 bolts. If you put a later torsion bar complete cross member in you will need the trans mount cross member and the hardware for a 70-76.
I want to replace it with same year if possible. My FIL modified the original for the B body transmission. I am just trying to fix that area
