timk225
I might be pulling the axle shafts out of the 7-1/4" in my 1973 Duster. Got my longer wheel studs and wheel spacers to make the rear track look less stupid from the back, and I doubt these 3" wheel studs will slide in without pulling the axle shafts out.
I looked online, and it seems that #2643464 is the OEM part number, but it makes no sense to use a 50 year old seal and expect it to seal, so I looked on the Advance Auto Parts website, and found what seems to be the same thing.
https://shop.advanceautoparts.com/p...xle+oil+seal&selectedFulfillment=store_pickup
It specifies a 2.3" housing bore and a 1.4" axle diameter, can anyone confirm these measurements? It looks right, but there's nothing like the feeling of being halfway through the job, setting the new part in place, and realizing there's no way it'll work, it is too big or small.
While I'm at it, if it needs it, I might clean and regrease the axle bearings, the grease surely is very old, and I put 2500 miles on the car last year. I'm not going to change the bearings, just clean and relube with Mobil 1 synthetic grease, the pink stuff.
