The complete axle assembly will swap as a direct bolt-in. Switching components between the two, I'm not so sure.
I know that the LBP axles off a '73-up rear end will not go into a '72 or earlier housing. The shafts are a larger diameter, the bearings are different, and IIRC the splines aren't the same either. The whole thing looked like they'd beefed it up. I am not sure if the '73 and later SBP halfshafts are the same as the '72 and earlier ones, or are like the '73 and later design only drilled for a different bolt pattern.
