I'm swapping some bigger drums onto my 7 1/4 and while I'm in the process I want to go ahead and change the oil. The problem is I can't seem to find a 10 bolt housing cover gasket. Anybody know where I can get one?
Easy one.....RTV gasket maker is the modern gasket.
Make sure both surfaces are clean and dry, apply RTV to cover, let it set-up for a couple of minutes then put cover on. Wait a while for it to fully cure and then add rear end lube.
