[FOR SALE] 70 340 Rad #2998978
2doorswinger
canada
Rating - 0%
0   0   0
Hey there FABO members! I've got a 1970 340 rad available with part number #299978. It's a clean rad with no leaks (was being used in a 69 340 swinger and was pressure tested after being removed). Removed to go to a bigger core aluminum. Looking to get $220 or best offer (obo). It's currently wrapped up in a box and pictures were taken yesterday (Aug. 6th/18).
Located in Milton, Ontario. Can ship out of Ontario OR Buffalo, NY OR Bring to Mopar fest in New Hamburg. Thanks!
Please note: you are correct on the top tank numbers for 70 & up A-body 340 radiator w/o A/C BUT the bottom hose tank is not correct for this original application as you stated the bottom tank is for 1969 & back application. Do you have the original bottom with passenger side lower hose opening? I am interested if you do. I will contact Glen-Ray in Wisconsin to see if they can make this to fit original application for my 70 Dart Swinger 340
What you see is what I've got, sorry!
