Mojack
This is a very presentable grille, a good driver or local car show quality grille. Someone has already done a casual refurb. When installed most imperfections would not be noticeable. A little more TLC and it would be a fine grille. It won't win you a Riddler. I've tried to show all the stress cracks in the grille and the lenses. Some pics are the same imperfection from a different angle. Lower tabs at both ends have been cracked partially away and the driver side upper tab, that the headlight ring captures, has been broken off. Someone was kind enough to cut the signal light wires free, ugh, connectors could be grafted on. Ask questions, I'll post all the pics you want. It will be well packed and insured. $225 plus shipping from Bristol, Tn. 37620
Thanks FABO
Thanks FABO
