[FOR SALE] 70-72 transmission crossmember
kyle's 340
70-72 transmission crossmember, fits auto or 4-speed cars. Good shape, just pulled from a 72 dart. No bolts. $40 + shipping from 40165. Thanks
The holes look to be 1/2 inch. see if you can put a 1/2 bolt though the holes. If they are the smaller holes then it is a 70-72 and it won't work on a 67-69 . The difference 3/8 inch crossmember bolts or 1/2 inch. You have it listed as a 67-72 . They are 67-69 or 70-72. The early style will fit on the later car but it will be loose on the bolts. I am only trying to make sure you have it listed correct so it doesn't get returned to you. Here are pictures of both , usually the later have an ovaled hole on the end.
