70 Dart horn bracket??
sabre67
B.C. Canada
Could anyone tell me on a 70 Dart if the 2 horns are mounted on a bracket then mounted to rad support? I only have 1 hole in rad support that is threaded for a bolt where the horns go, all i have is the wiring harness there now. If it is would anyone have a picture of that bracket. Thanks sabre67
Each horn has it's own bracket
looks like 1 is mounted to rad support is the other mounted to inner fender?
Ok thanks i have to look again for the second mounting hole? Unless 70 was offered with 1 horn only?
The horns have a threaded bracket they don't take threads on the body. The top two holes sise by side in your picture above the horns. The little and larger hole . That is where one of them goes. The other is hidden somewhere behind your horns. You have the wrong horns. second picture you can see the two bolts holding the horns. They thread into the horn brackets from the front
Yes, both are mounted on the radiator support and have their own bolt hole.
