Teegjohnson
New Member
So my dart has been swapped from column auto to floor shift auto long before I got the car. Putting in all the QA1 goodies, and you have to put one of the pictured bearings in the column for the new steering set up. The old shift tube was in the was so I drilled out the spot welds and tried to just pull the lower one, and the front came with it…. Not all the way though! How can I get the upper tube out, and will taking it out negatively affect anything else?
