gregpurcell
Greg Purcell
Perhaps you have seen this car listed in the past as a whole body. I finally parted it all the way out leaving just the shell. Every usable piece has been removed except for the rear glass, quarter panel extensions, rear valance and trunk and door hinges.
If you are working on a project Dart which will require frame rail replacement, this shell might interest you! Put your sheel metal on THIS body! The rails are all very good and because this is a numbers matching 340 car, they are reinforced with torque boxes! The area under the hood is great, as are the front door jams and inner fenders. The trunk floor is very repairable. The interior floor has the hump removed and the drivers pan needs replaced, but the rest of it could be patchable. It does need quarters, but the trunk lip and window edges are very good!
70 Dart Swinger Original 340 Body Shell: $900 Delivered to the Mopar Nats. $700 pick up in Savannah, GA
Again, you are getting an original 340 stickshift body! The numbers are stamped two places in the body. The fender tag is still in place. I have the vin tag and a set of rivets. The VIN sticker is still on the door which you can have for an extra $100 if you want it (it's a nice door). There is no title because Georgia doesn't title old cars. I can only give you a bill of sale.
If you are interested in this shell you will have to act quickly. I am leaving for the Mopar Nationals on Wednesday Morning the 7th, so you will have to contact me before then if you want it delivered. If you are closer to Savannah and would like to pick it up (after I get back from the Nats) you can have it for $700.
