70 Dart Swinger Wiper Knob Removal
Gibber
Godley TX
Does anyone have a trick to getting the wiper knob off? I can't take the dash bezel away from the cluster until this knob comes off, and it looks like a press fit. I can't see how to get it loose from the wiper switch shaft without breaking something....
Thanks,
Mark
There was once a small allen set screw in that knob. At some year model the set screw changed to a small piece of tempered steel inside the knob. Without some special tool ( that I've never seen ), all we can do is pull the knob. Try not to loose the little keeper thingy, they do fall out.
OK Thanks,
It has no set screw, so I will try just pulling it off. Worse case is that it gets cut off and I buy a new knob...the gentleman whose cluster I'm rebuilding understands that...
Thanks again,
Mark
