'70 Duster Dash Frame Removal
dust44d
What's An A Body ??
Rochester,MN
Could someone give me the "in order" steps to remove a complete dash assy from a '70 Duster.I need to replace or repair the radio opening along with pulling the guanges for resto,painting the dash frame,etc. E Bodies I can do in my sleep,but these A Bodies are new to me!! Thanks for any tips
With the windshield out it's pretty easy.
Drop the column.
Remove the 5 or so screws at the windshield edge and the two bolts at the lower corners nears the kick panels.
Disconnect the bulkhead connector and heater cables/wiring. There are some additional electrical connectors at driver's side kick panel that feed the rear. Dome light switch wires (both sides). Speedo cable. E-brake handle.
That's pretty much it. Anything I missed will be obvious.
If the windshield is in then you may be able to cut the front screws from underneath. To reinstall you would put the u-nuts on the dash frame instead of cowl and run short screws in from the underside. The windshield gasket hides the screws.
