[Found!] 70 Duster Door, Hood, Trim, Shroud & Radiator
TommyP
Dallas
Hey guys, I'm needing a 70 Duster Drivers Door & Hood. I need them clean with no rust holes or cut-up. I'll be at Carlisle to pick them up if that helps. Also I'm needing the complete vinyl top stainless trim (6 pieces). In addition it would be nice to get a fan shroud & radiator for a 4-speed #2998978. Thanks Tom
I would have all your parts and I live near Carlisle. The parts I have are pristine. Rad. and shroud are still in the car. The Doors are still on the car Plus I have 8 more. The top parts are off and they are perfect. A-pillar , both c-pillar pieces including screws and all hardware No pitting or sun fade on the four chromed corners.
Depending on your offer I can deliver them to Carlisle or you can pick them up when you are here. Did you know that the stainless for the drip rail is different for a vinyl car. Its wider.
I live in Danielsville Pa. If you low ball me I won't reply. So far I have no reason to go to Carlisle unless I am delivering other parts or hauling a car. I won't ship sheet metal parts they never arrive in the same way they are shipped. I would need an advance notice if you want them.
I have a door from a 72 Duster if that helps. Pm if your interested
Thank You but sorry no, 72 had different mounting holes for the window whiskers and that's exactly what I've currently got. Thanks again for the offer.
