JamesRR
Looking to possibly trade my Drag Car for something a bit more mild. This car screams and has not been the best for me, a novice racer. 500ci Big Block. 13.8:1 Solid Roller Cam around .700 final lift with 1.7 rockers. B1 heads. Open headers. Jegs Electric fuel and electric water pump. New Radiator. Full MSD Ignition system. No alternator. Battery cut-off switch. Trans is a built 727 with shield and trans brake. 5,600 stall. Quarter stick shifter. Front disk brakes, large drum rear with line-loc. Car is tubbed with Dana 60 rear end. 4.88 spool. Autometer gauges and tac. All good stuff. Slicks on rear only have about 5 passes on them. 1 aluminum racing seat with harness and full sheet aluminum interior. Roll cage. Lexan windows. Fiberglass removable front end. Leaves straight and pulls the front wheels. Im sure I forgot some things. Just ask. I did not build the car. Bought it done. I have been in the mid/upper 6's in the 8th mile but I have never left off the transbrake. Was footing it. This car can dip into the 5's if driven correctly. Car is scary fast and sounds bitchin. Paint and body not perfect but looks very presentable. No rust. Bill of sale only. I would value this car somewhere in the 16-17k range although it could not be built for that figure new. Looking for a comparable pro street or race car that is quick but a little more tame to learn on and get consistent. Must be Mopar. Preferably a 60s car. Thank you
[ame="https://www.youtube.com/watch?v=_eGqVac0wzg&feature=youtu.be"]IMG 6381 - YouTube[/ame]
James
James
