Tape off the paint on your fenders at each end where the bumper might contact it while you are setting it into place. If I recall, the chrome on the backside of the bumper is a bit sketchy so I put some sort of sealer coat on there so it didn't rust- can't remember what the sealer was though. Use new bumper bolts, lock washers and nuts, and don't over tighten them. AMD bumpers do not have as thick of metal as factory bumpers. Try to be on a level surface for the final tightening. Keep a tape measure handy in case you need it. It's easy enough to do- you shouldn't have any problems.
