Robj
Large Red = battery feed Connect to red lead of meter
Yellow = starter solenoid crank position
Brown = Ignition crank position
Blue = Ignition run position
Black = ACC run or ACC position
I'm assuming you could check a switch either out of the vehicle or unplugged while still in the column by using a 12 volt power supply or battery? Connect the negative lead from the meter to the negative on the battery and then connect the large red from the switch to the positive on the battery and then check each of the Y, BR, BL and BK wires with the red lead from the meter while placing the switch in each position?
