After installing a rebuilt PS Box I still have a lot of play in the steering. Can someone tell me the procedure for adjusting the steering box. All suspension parts are in good shape and I had a good alignment done!
There is a nut on the top of the box that locks a allen set screw. hold the set screw from turning and loosen the lock nut a turn then turn the set screw in a half a turn. see if that helps the slop. if so make sure you can turn the wheel from lock to lock with no tight spots. if you can and you still need more adjustment turn the setscrew in some more until you get the slop out. repeat the above steps to make sure you don't get a tight spot. if you do get a tight spot back the screw out a little until no tight spots and lock the nut at that spot.
