70 duster tire?
Izzonyg
Massachusetts
What is the largest rear wheel and tire I can fit on my 70 duster without having to offset?
i have run 28x11.5 slicks with a 10 in wheel
and am currently running 15x10 with 295/50/15 radials
and have no issues. had these on my 73,74,75 dusters
So if I bump up from the stock 14 inch wheel to a 15 inch wheel can I still get 275's on without doing some type of offset or spacing? Or am I better off goign with 255's and a 15 inch wheel?
255-60-15s are an easy fit on a Duster. 15X" rim with a 4.25" backspacing. You should be able to get a 275-60-15 on a 15X8 with 4.5" backspacing also.
i run a 295-50-15 10 inch rim
i also run 295-50 on my duster and my dad is running my 255-60's on 8.5in rallies on moms duster both look good.but the 295's look better and on a 10in wheel with i cant remember its either 4.5 or 5 in back spacing they fit great and nothing has to be modified
