70's Demon 8-3/4 fit in 63' Dart?
luvbeer35
I'm looking to replace the 7-1/4 in my 63 dart GT convertible with an 8-3/4 from a 70's dart/demon. Bolt pattern is the same but not sure about the overall length drum to drum, leave spring location, and drive shaft length?
Thanks for the help!
Driveshaft will need to be shortened, Other than that, it should be a bolt in deal. You do need the right lower shock mounts though because the tubes on the 8.75 are larger than the 7 1/4.
