zac_F71
I just talked with my Uncle and he has no interest in my Demon's 225 slant 6/ A904 trans
I am not advertising anything locally as it is less than wanted in my area.. all for trade for just about anything Mopar A body related or cash as well so make offers I'm tired of sitting on this stuff... will ship the small stuff (not the motor/trans) can deliver to Mopars in the Park car show at Dakota county fair grounds in Farmington MN on the 30th/31st as well
71 225 slant 6 -
90,000 original miles
great running motor
new timing chain
new water pump
new chrome valve cover
new cap/rotor/plugs/custom Taylor plug wires
new NOS fuel pump
new reman alternator
new V belt
new motor/trans mounts
fresh oil change (0 miles on it but was changed 8 years ago)
electronic distributor
A904 - needs nothing works great - put new trans filter/pan gasket on and hasn't been filled yet (I'll include the cooler lines as well)
stripped oil pan drain plug threads - I will run a tap in it and see if they clean up (if they do will include a new plug)
- i have a later EGR aluminum 1bbl intake/exhaust mani, and Holley 1920 carb for it - carb needs rebuilt, and put on - also have new kick down linkage as I was running a lokar cable setup..
1973 A body 7.25" rear axle, rebuilt at one point - gear lube VERY clean, has green bearings on axles, no brakes, big bolt pattern
7.25" shock plates with newer 2.5" U bolts, 1 plate missing a correct shock washer but there is one there
71 A body upper control arms - new ball joints - 1 welded in - need bushings
71 A body 2.5" 6 cyl leaf springs w/ new rear shackles - needs front bushings - includes front hangers in great shape
26(red) & 29(black) tooth speedo gears
Set of 4 Monroe shocks - brand new installed and car sat - still in great shape
71 225 slant 6 -
great running motor
new timing chain
new water pump
new NOS fuel pump
new V belt
