[WANTED] 71 318 2bbl intake
Shannon Buff
Active Member
mid west
Rating - 0%
0   0   0
Looking for a good OEM 2bbl cast iron intake for a 71 318 in a Dart Swinger. Mine cracked around the thermostat area according to the machine shop. I am also looking for a Rochester carb 7041180 mainly for the body-float bowl. Thanks FABO!
Do you have a part # for the intake? Do you want original? I may have a couple here.
I have one (with the carb (not sure what carb it is)) I took off my '71 Dart GT 2 summers ago. It's yours if you pay for shipping (my zip code is 48044).
I dont know what the part/casting number is. I can call the machine shop in the morning to find out. I want to keep it as close to original as possible. Was there multiple 2bbl intakes available? A pic would help me identify the intake I am looking for. Thanks!
Was there only one 2bbl intake available for the 71 318? If the intake works for my application, I will take it. If the carb is what I need then that is a bonus. The idiot that I had rebuilt my carb put the check balls in the wrong places so he drilled two holes in the bottom of the accelerator pump cavity so he could knock the ball out and used JB weld to seal the holes. I knew nothing about it until I took the carb off the other day. Friggin jerk. Sould have rebuilt it myself I guess. My zip is 52659 thanks!!
I have a 2 barrel intake from a mid 70;s 360 you can have, it's in my way if it helps.
Gosh I wasn't expecting all of this help lol! Let me see what DartGTDan says about his intake. I want to stay as close to the 71 intake as I can get. Thank you!!! I may be in touch!
