I have a friend that has a 1971 340 he'd like to sell so here's the scoop on his 340. If you need, contact me here and I'll forward his contact info to you, then. Thanks, much appreciate...wb
1971 Mopar 340 Engine . Run's, will need to be gone through . Block casting number # 2780930 -340-5 . Block casting date # 1 / 18 / 71 . Both " J " Head Date Code's # 0 5 4 1 # 0 5 6 1 . Can't read date code on Factory Thermoquad Intake well . This is being sold as running with no knock's . Hold's oil pressure , Run's with cooling system sealed up . You will get the long block with factory intake, water pump, oil pan, valve cover's Just as the video's show . No warranty expressed or implied . As is . Prefer Buyer Listen's To It Run Cold And Warm Before Taking Possession $3,000.
Located in Rockford, Ill...pan rail number...1A187851
