71 dart steering coloum/ ignition switch
kickywow
Delta, B.C.
so i traced an electrical problem back to the ignition switch in my 71 dart swinger, but im stuck now i cant get the steering coloum apart to replace the switch, do i go from the steering wheel and remove it, theres no bolts or screws on the piece that is containing the switch. , i have the plastic and the metal removed from the bottom where the wires are contained,if there is someone out there who has done this or knows how to could you give me some advice.
i consulted my haynes manual under the section of ignition switch replacement, all it said was to replaced steering coloum cover it did not say how](*,)
