1971 Dodge Demon 340 clone
Street / strip car with current tags
featuring PPG Viper Red base / clear
Organsal black out treatment
Phoneix Graphic stripes
AAR lift off 4" cowl hood / front bumper / front valance
NOS tail lights / restore grille
car must be seen in person
runs 6.40's in 1/8
low 10.0's in 1/4 in full street trim @ 3200 lbs.
featuring :
362 CI small block
mopar R1 48 degree block w/ oiling mods and bushed lifter bores
BRC race 3.500 stroke race crank
manley steel billet I beam rods 6.250
Diamond custom W5 forge dome pistons @ 14.1 compression run on 112 sunoco fuel
Comp solid roller cam
crane pro series roller lifters
Mopar W5 heads with full race port 317 / 245 flow thru Ti intake valves and SS exhuast valves
1.6 T&D roller rockers and 3/8 smith bros. pushrods
Custom polished Hogans sheet metal intake w/ 4500 flange
1050 Dominator
Charlies alum. oil pan
Moroso remote oil filter w/ Fram HP6 race filter and -10 an lines
moroso elctric water pump
fluid damper w / moroso billet 5" pulley
custom low mount alt kit w/ march race pulley
polished sheet metal valve covers with billet locking breathers and -12 an hoses
roll master billet chain
ARP fasterns thru out
MSD billet Dist / MSD digital 6 box / 8.5 wires / blaster coil
TF 904 trans
8" ATI / MRT pro series 6200 trans brake convertor
low gear set
billet servos A&A
muti spring front pack A&A
solid bands A&A
Red clutches and keno steels A&A
TransZat Pro brake
Mopar deep pan
mopar SFI flex plate
RCI blanket
Dyno tech 3 1/2 Alum drive shaft with solid 1350 joints
Mark Willians front billet yoke / forge rear yoke
drive shaft loop
Dana 60 rear with 35 spline spool and race axles / moser ends / LWP Ultimate cover / CE wheelie bars / CE ladder link bars
QA-1 coil overs 12 ways with 130 lb springs
TTI race 1 7/8 ceramic polished headders to a 3" custom X-pipe to 3 1/2 top ten shootout flowmasters
Mag Force upper tubbular Heim joint a-arms
all new ball joints/tie rods/pitman / idler
CE 90/10 shocks
notck K-frame with solid mounts
Griff Alum Rad.
zirgo 3300 cfm elect. fan
perma cool 6 pass trans cooler
Areo space billet 4 piston brakes on all 4 corners
Adjust prop valve / hust line lock
Full auto meter gauges
Hurst Quarter stick w/ Cheeta comand center
15x10 & 15x4 weld pro stars
moroso front drag speacials 26"
29.5 x 10.5 rears & 29x14.5 Hoosier QTP's
Mcguard open face lugs
20 gal. alum fuel cell
BG 400-2 pump and 5000 filter
BG 2 port reg.
-10 / -8 an lines
dual opt. batteries w/ HD moroso shut off and remote charging
full Black interior (very nice) w/ Kirkey alum. fronts and RCI 5 way belts
8 point cage / frame ties / 2x3 front ladder bar cross member
all stock glass and work
grant wheel
paint is 95% show quailtiy
cowl and engine compartment is smooth
this was a 2 year build with dyno time and 40 passes on drive train.
im sure ive left out some things
the car started life as a duster and i converted it to demon specs.
SERIOUS ONLY $35,000.00
or possible trade for E-body 70/71 cuda
come see it and i will take ya for a wild ride :toothy10:
will be at the CC Event at Martin Mich. the 21/22 of july
PM me or give me a call
thanks Bob [email protected] 567-232-0200 cell 5 to 10 EST please
thanks forabodiesonly for the add
runs 6.40's in 1/8
featuring :
362 CI small block
1050 Dominator
TF 904 trans
low gear set
billet servos A&A
solid bands A&A
TransZat Pro brake
Mopar deep pan
RCI blanket
drive shaft loop
CE 90/10 shocks
Griff Alum Rad.
BG 2 port reg.
-10 / -8 an lines
grant wheel
