I'd have all 3 angles checked (complete 4 wheel alignment), but toe is the angle that will cause the steering to move off-center. Always insist on a true 4 wheel alignment even though there is no adjustment on the rear axle. If the rear isn't positioned perfectly perpendicular to the vehicles centerline it will affect the front ends alignment since the front end toe is calculated off the rear wheels track. A 4 wheel alignment will take into effect the rear axle's position & compensate from that. Alignment should be adjusted in this order: Caster, Camber & lastly Toe.
:burnout:
