dusterdemon
Has anyone used a dash pad from BE&A? They are quite a bit cheaper than other suppliers. Curious about the quality. Thanks Warren
Any particular reason that you 'reported' your own post?Has anyone used a dash pad from BE&A? They are quite a bit cheaper than other suppliers. Curious about the quality. Thanks Warren
I already did that. slip up.Any particular reason that you 'reported' your own post?![]()
This has been mentioned before but , in case you missed it, make sure the replacement pad has a metal core.Has anyone used a dash pad from BE&A? They are quite a bit cheaper than other suppliers. Curious about the quality. Thanks Warren
