[WANTED] 71 Demon grill mounting bracket
These are what you are talking about I believe. I haven't had any luck and when I get to that point I will have to figure something out. They mount inboard of headlights for the straight tabs.
Grille brackets 71 Demon
Its a metal L bracket that bolts to the rad support on one side of the bracket and the other protrudes 90 degrees allowing the grill to be bolted to it, I just need one of those.
I've got a 72 and I am in the process of putting it back together does 72 require them also? I don't remember them when I took it appart
I don't know of anywhere they are available. I'm in the same boat. I need two of them, but when I get to that point I will probably make my own some how.
