71 Demon remote mirror ??'s
EL5DEMON340
Aurora,IL
Mirror Remote should be mounted to the top of the door , just in front of the demon door tag correct? Someone way back when mounted it to the door panel in front of the window crank. and used a 2999001 bezel, i need the 6027749 bezel correct, Where is the best place to find this bezel? thanks Mike
Hey Mike, swap meets and ebay, the same bezel was used for both styles of remote mirrors (sport/rallye). You will likely need to by a complete mirror, as finding the bezel separate will be difficult. Hopefully you can find a loose and pitted mirror for cheap.
The bezel on the right hand side is the one you are looking for (P/N 6027749).
By coincidence the bezel on the left is a 2999001, I believe for '68 Barracuda.
All the best!
Hello Mike, I have an extra one of those. PM me your info.....:wave:
