71 demon seat,and dash ??
truckerlee379
71 demon
ohio
hello,just bought a demon, and the buckets that he had for it are wrong..the ones in all the pictures on here look alot like e body seats..?? are they the same frames (i still have a set from a 70 cuda) also just found a 1967-69 fast back cuda in a junk yard up the road..question is to get the rally cluster to work in my demon..do i need the whole dash??or will the cluster work in my dash..i dont want to mess with my vin..also is the wiring diff?? thanks everone
the wiring is different. your dash frame will not work if it is not a rally dash, which came in the 340 car only for 70-71.
as far as seats. the frames are the same. the track sit 1 inch lower if they are out of an e body. the covers and foam are different from a body to e body
ok thanx,dash sounds like to much work..if the seats that came with the car are a body can i change the tracks over to the ebody frames..really didnt want to buy foam,,but what u gonna do i guess..all need recovered..
