BerryMoparBloodline
Does anyone know the max diameter/width wheel I would be able to put on my '71 Demon without mini tub? It seems I am getting mixed information from different sources. I've read where an 8"wide wheel is the widest I could fit all around. I was assuming I could fit 18x8 on Front and 19x10 on Rear without any major mods. I will be running a Wilwood disc brake setup, 8 3/4 ABody rear, tubular UCAs, stock LCAs. I was assuming I could run this setup based on the wheel/tire specs given by Kenny Wayne Shepherd for his '70 Duster. I've yet to hear or see anything mention his car being mini tub.
Thanks In Advance,
BerryMopar
Thanks In Advance,
BerryMopar
