[SOLD] 71 DUSTER 383 A/T NICE EVERYTHING
the mopar dude
Head Dude
Burlington, Kansas
Rating - 0%
0   0   0
71 Duster, Vitamin C orange, black bucket interior, 383 4 bbl, console shifted 727 automatic, 8.75 rear with 373 sure grip, power steering, manual brakes with Wilwood front disc.
Paint and body are very nice with no problem spots, has been completely color changed a few years back and well kept since then. Floor pans have been correctly replaced. No rust in trunk or framerails. Bumpers are all steel and have been powder coated black. Remaining chrome is in good condition. New mirrors.
Engine is a 68 383 and acts totally stock. Radiator is a 054 unit from a big block B body and works perfectly in conjunction with a 160 thermostat. Engine is solid mounted with custom L brackets to the stock locations. Stock B body magnum manifolds with full dual exhaust, Edelbrock performer 383 intake with a Holley dual feed single pump electric choke 650 carb. Stock Mopar electronic ignition. Transmission has a 2400 stall convertor but is otherwise stock and shifts firmly. Rear end is an 8.75 with 373 gears and retains the 4" wheel bolt pattern. Front suspension has been rebuilt with polygraphite bushings, and Wilwood discs were added at that time. Front brakes are also 4" pattern. You would never be able to tell they were manual brakes unless you knew beforehand. Tires are BFG 215/60 front and 245/60 rear with bunches of tread left.
Interior has been completely re-done with new headliner, seat covers, carpet, package tray and a dash cap. Dash wood grain is very nice and nothing on the dash has been butchered. Still retains the original non-working AM radio for that stock look.
This is a very nice, normal driving car. I had no problems taking it on a 300 mile trip in one day. Runs 3000 RPM at 65 MPH comfortably, temp stays at 175 degrees no matter if you are stopped or going down the highway and maintains 50 PSI oil pressure at speed. Transmission shifts and downshifts just like its supposed to. This is a good all-around driver that takes no special instructions or procedures to drive it like a normal car. If you have ever wanted an A body with a big block, this is a good one you dont have to build to drive.
Car is located in Burlington Ks 66839
$12500
Would you take *** for it?
(Please contact the seller through a private conversation with your offer) tmm moderator
