71 Sail panels in a 74 Duster?
74Dusted
Stock Piler of 340's
Lewistown, PA
Can the sail panels be swapped over with no mods? I need to replace the driver side door on my 74 and was going to swap on a pair of 71 doors and figured I'd put in the matching sail panels too. I'm not sure if they'll fit with the 73+ headliner though.
Anybody know if the panels can be swapped without modifying something?
The older one is lacking the length to go to the rear window. I welded an extension on, and bagged it with carbon.
Andrew
Ah, I forgot about the sail panels being shorter.
Thanks for those pictures, blue missle. They give me some ideas on making a "filler" panel (maybe even put a set of speakers in the filler panels), so I don't have to modify a set of mint sail panels to reach the '73+ headliner
