What are your goals, I'm sure someone installed the 8.3/4, do you have any idea what gears are in it? I've heard good things about the Hughes Engines "Whiplash" cams, they work really well for lower compression engines, plus they sounds great, I'd get there imput on a cam/converter/gear set-up, A 750dp should work really good on a 383, What intake you running? Heres the cam with sound clip, may need there springs too.
http://www.hughesengines.com/Index/...V2hpcGxhc2ggTXVzY2xlIENhciBDYW1z&partid=25115
http://www.ptcrace.com/street-strip....html?osCsid=1ec6f63e56ca6c1cf49d32292fdd8ed6
This is how i would set it up if it were mine.
Whiplash cam.
SD intake, 2nd. choice RPM
750dp
MP distributor & chrome ECU
Shuamacker headers (to keep cost down) should be plenty of header for a mild 383.
32-3400 9.5" converter from a reputable source, No junky TCI or Boss Hogg, get a "real" converter that has great street manners, a PTC would foot the bill, I ran 4 of there converters & was very happy.
3.73 too 4.10 gears, 27" with 3.73s/28" with 4.10s
MT or Hooser DRs.
This will definitly wake it up big time if the engine is fairly stock at the present time.
Just looked at the shuamacker headers, damn them things went up in price
