71 Torino
newmexguy
Las Cruces New Mexico USA
U pull it yard i frequent has a 71 torino i discovered last week. Last year of the unitized design. Four door, was small V8 with three on the tree. Pedals were already taken, i checked. Rear end was still under it and was complete. Leaf Sprung. So is probably non posi w/ 2.50, 2.75, 3.00 etc ratio. Appeared to be nine inch. 4 1/2 bolt circle. Any value or swap possibilities??
9" and 8" looks very similar. Id double check. As far as the swap sure it has possibilities. It will need to be cut im sure. Lots of aftermarket options avaliable for the 9"
