airgrabber
Started life as a 71 column shift manual steering column. Disassembled, bead blasted, repainted steel parts with epoxy gloss black. Replaced column shift collars with 71 style floor shift collars painted satin black. Removed shift tube. Cleaned and repacked pot coupling. Can also swap collars for 1970-only collars, which have no instruction decal or key release tab. Replaced directional signal cam switch. Has key switch and turn signals, takes your key assembly. or add $20 for a key switch and key. Not shown but will provide turn signal arm and screw, roll pin for connecting to steering box.
$250 plus shipping in the USA from Florida, add 3% for Paypal.
