airgrabber
This is manual steering box column that I converted to floor shift by adding the correct collars for 1971 and up. The entire column was disassembled, bead blasted, repainted in satin black. Includes turn signal and ignition key wiring/harness and turn signal arm. You supply the key switch to match your existing door keys - it simply slides into the spot for it - no dis-assembly required. $250 plus shipping from Florida. US Post office money order or paypal plus 3%.
