hockeydad1189
just ran the numbers on my carb it is a carter afb 625 cfm. i was reading on line that the 340.s came from the factory with 850 cfm is that correct and is 625 to small
71 up got tq 850 cfm , 70 down came with carter AVS 650 , the edy 750-800 would be a good choice , easy to maintain / upgrade if you get a good one . Holleys are great but I was always having to adjust , change power valves , fix leaking bowls . But they gave a bit more power .just ran the numbers on my carb it is a carter afb 625 cfm. i was reading on line that the 340.s came from the factory with 850 cfm is that correct and is 625 to small
