72 Dart drum/disk swap
MemphisDart
Memphis,TN
will a 1988 chrysler fifth avenue be a suitable donor for disc brake swap? if not, what should I look for?
need BBJ upper arms or sleeves, good from the spindles out.
sorry, those parts won;t work on your car
Not true at all. :sign6:
Everything from the spindles out will work just fine as crackedback already mentioned. He just needs bbj uca's or the adaptor sleeves from dr. Diff.
Any fmj car can be a donor for a BBP disk swap, includes cars all the way up to '89. Spindles, caliper brackets, rotors and calipers will all swap. Some of them might be pin style calipers, but if you take it all it doesn't matter. You just need '73-76 lower ball joints and BBJ UCA's or sleeves for the small ball joint arms.
I do have a set of magnum force tubular UCA, they are already powdercoated. I am going to be putting up for sale for $200 shipped to lower 48 States.
