mikess68
i have need of some experience.
put the hood back on the swinger. it has a straight gap on the pass side and on the drivers side. however the hood wants to set to the passenger side more, like it needs to be shimmed toward the drivers side. if you push it down onto the rubber bumpers it centeres up, but then a little bump and it drifts back over to the pass side. the first impression is to move in the drivers fender 1/4 inch, but looks like that will be very hard. i can push it over to the drivers side and it centers with the right gap on both sides, but like i said slighest movement and it settles back to the pass side. so, how do i move it over to the drivers side. shimms, open hood and push it over making the hinges spring over that way, or what. can t be the only person ever had this issue. i have painted uner the hood and really don't want to unbolt the fender. ????:clock:
