element303
Can someone point me to a website where I can order a rebuild kit for the stock 72 Demon Carburator? All I know is that its a Carter. Dont know the exact model though.
Since I am already on it maybe you guys can help me with another issue relater to the Carb.
I have the problem with the carb only when the engine is hot. It starts right way, mostly without even pumping and idles very steady. Once the engine is hot, its bogging (I think thats the right word in english) when I reapply the throttle after coasting or when I accelerate from standing. If I push the throttle its bogging for a moment until it accelerates normally. Sometimes it almost turn off the engine before the rpm comes back up. Also, when I am cruising on the same level with the throttle, it feels like its hesitating up and down slightly and as if someone is pulling me back. Full throttle everything is fine though. The carb is (or should be) completely clean, I also installed a new fuel filter. Any suggestions would be welcome.
Also, not sure if it helps to identify the problem but when I decelerate after going a little faster I can smell gas but its not the typical unburned gas smell.
Thank you
Thank you
