72 demon fuse block with 7 fuses. wiring schematic shows 6???
northeastmopar
Massachusetts
My demon has 7 fuses in the fuse block. Part number 3588198... my manual shows only 6 and has part number 2291593?? Can anybody here clarify this? I did buy a used good harness for this car and it appeared to look the same?? My car is a stock 340 a/c car???
My Demon 340 a/c car I just checked and it only has 6 fuses. I can't read the part# so I cant comment on that.
My 72 demon has 7 fuse slots. The old harness also had 7 slots. in both the 7th slot was inoperable without adding a fuse end clip. This slot is for any accessories you might add to your car. If in fact you actually have a fuse installed in that spot does it have a wire leading from it , where does it lead to?( the other end will be hot with the switch) if not possibly a PO just used that spot to store an extra fuse.
Yote
