72 Swinger brake booster
sparkyct
Active Member
Stamford, CT
I'd like to put a brake booster on my '72 Swinger. Is this a hard job? What extra parts will I need?
There is a bracket with linkage mechanism required between the booster and firewall required. Two braces the factory added around the booster are a good idea too even if not absolutely necessary. The vacuum port in the intake manifold... I think that's all
