dart540
Late 76 Dodge Truck Trans with bolt on yoke just finished building has new pro series flex kick down band,kevlar low reverse band,4-pinion alum.,planets frt/rear,B&M shift kit for towing,low rev.,servo made solid,acc blocked,front servo 90# spring, new pump gears,gasket,seals,bushings,Borg-warner clutches/steels,4 front Drum 4 rear drum,3.8 lever,H.D.band strut PM for information $900
Free Delivery in USA
Other Trans Available
