727 Bushing Sizes
jar84203
Member
I am planning on rebuilding a 727 from a 66 Dodge and was wondering what the bushing sizes were. Thanks.
Generally speaking, if you deal with a reputable trans parts supplier, they can get you a kit with all the bushings that the trans needs.
If I were to measure the new bushings, would I measure inside or outside diameter to determine the needed driver?
Both. The proper driver will be a stepped driver, and fit inside the bushing, as well as just cover the full diameter. If you use a seal driver, which is flat, be careful and use one that is large enough to fit over the full diameter. If the bushing is to be driven past flush, check to be sure the driver will fit in the bore, but still sit firmly on the bushing edge.
